Compilation error
Note: This was originally posted on 30th August 2012 at http://forums.arm.com
[size="3"]  I never set the directory "c:\Program".  Why is there such an error?
This is the error information:
**** Build of configuration Debug for project startup_Cortex-A9 ****
make all
C:\Program: C:\Program: No such file or directory
make: *** [sorts.o] Error 127
**** Build Finished ****[/size]
  • Note: This was originally posted on 3rd September 2012 at http://forums.arm.com
    Thanks a lot. I think you are right. Through your help,I have resolved this error.
    I am guessing you are building one of the example projects that is suppled with ARM Development Studio 5 within Eclipse IDE. I recall there is a problem with autogenerated makefiles not properly being quoted or escaped when they contain spaces. Check where your workspace and example project are located, and if they are in C:\Program Files\ then move them to a new location that does not contain a space.
