How to boot Linux on  ARM core with only ARM instructions set
Note: This was originally posted on 20th August 2012 at http://forums.arm.com
Hi all,
On the ARM core with several instructions sets,I just want use ARM instruction set to run Linux,Is that possible? if possible,where need to be modified in the Linux?or just to modify the .config file? Any reply will be appreciated.
             Thanks a lot,
              Heron
  • Note: This was originally posted on 20th August 2012 at http://forums.arm.com
    My first question would be "why?".  You have to go back a long way to find an ARM processor that doesn't support Thumb (StrongARM anybody?).
    Second question, what is it that you mean by ARM only?  Do you mean build the kernel as ARM?  Or not allowing Thumb apps?
