Site
Search
User
Site
Search
User
Groups
Arm Research
DesignStart
Education Hub
Graphics and Gaming
High Performance Computing
Innovation
Multimedia
Open Source Software and Platforms
Physical
Processors
Security
System
Software Tools
TrustZone for Armv8-M
中文社区
Blog
Announcements
Artificial Intelligence
Automotive
Healthcare
HPC
Infrastructure
Innovation
Internet of Things
Machine Learning
Mobile
Smart Homes
Wearables
Forums
All developer forums
IP Product forums
Tool & Software forums
Support
Open a support case
Documentation
Downloads
Training
Arm Approved program
Arm Design Reviews
Community Help
More
Cancel
Developer Community
Tools and Software
Software Tools
Jump...
Cancel
Software Tools
Arm Development Studio forum
Cortex-A5 NEON issue
Tools, Software and IDEs blog
Forums
Videos & Files
Help
Jump...
Cancel
New
Replies
Subscribers
126 subscribers
Views
Users
0 members are here
Related
Offline
Jason Martin
over 7 years ago
Note: This was originally posted on 2nd June 2012 at http://forums.arm.com
In attempting to use the NEON core on the Cortex-A5, I've encountered issues with the VST instruction. This seems to be reproducible when using the upper q registers(8-15).
The following code was tested:
[size="2"]vmov.64 q11, 0x1000000001[/size]
[size="2"]vadd.i32 q12, q8, q11[/size]
[size="2"]vadd.i32 q13, q9, q11[/size]
[size="2"]vst4.32 {d24, d25, d26, d27}, [r1]![/size]
[size="2"]vst4.32 {d16, d17, d18, d19}, [r1]![/size]
[size="2"]vst1.32 {d22}, [r1][/size]
[size="2"]r1 points to an address in RAM. [/size]
[size="2"] [/size]
[size="2"]When q8 - q13 registers are used, the value being stored by the vst4.32 are incorrect. When using q0-q4, the values are always correct. When using a combination of q0-q4 with q8-q13, the issue is also present and bad values are being stored. These instructions worked fine on the Cortex-A8 with NEON. Is there a difference here that I'm not understanding? [/size] [size="2"]Are there limitations using registers > d16? And I believe it's also true that the Cortex-A5 uses the vfpv4? Which is D32, not vfpv3-D16. [/size] Thanks
Offline
Luke Dare
over 7 years ago
Note: This was originally posted on 7th June 2012 at
The Cortex-A5 has a configurable MPE / FPU option, it supports the following:
None
VFPv4-D16
VFPv4 and NEON
The configuration of the Cortex-A5 will be implementation specific, what device are you using?
It may be that you only have the VFPv4-D16 configuration in your implementation.
Cancel
Up
0
Down
Cancel
Offline
Luke Dare
over 7 years ago
After re-reading your post I see that if you did not have the VFPv4 + NEON configuration then the code would fault. I assume no faults are generated, but the stored data is corrupt?It would be useful if you could show what exactly is in them registers and the corresponding stored data in memory?
Cancel
Up
0
Down
Cancel
By title
By date
By reply count
By view count
By most asked
By votes
By quality
Descending
Ascending
All recent questions
Unread questions
Questions you've participated in
Questions you've asked
Unanswered questions
Answered questions
Questions with suggested answers
Questions with no replies
Answered
Failed to read contents of Internal RAM L1-I_DATA in ARM DS
0
Cache
Debug and Trace Services Layer (DTSL)
13529
views
23
replies
Latest
4 months ago
by
Boon Khai
Answered
DS-5 connect fail when cortex-r5 is in lock-step mode
+1
11225
views
10
replies
Latest
5 months ago
by
Stuart Hirons
Answered
On Cortex-M4F microcontrollers: is fixed point math faster or floating point?
+1
10779
views
10
replies
Latest
5 months ago
by
Ronan Synnott
Answered
Debugging kernel: OS support not working for Linux 5.4
+1
Kernel Developers
External Hardware Debug
Debugger
9649
views
5
replies
Latest
5 months ago
by
sgoldschmidt
Answered
DS-5 bare metal wait error after run "debug"
+1
DS-5 Development Studio
Debugging
Arm Compiler 5
Memory
32547
views
14
replies
Latest
5 months ago
by
prasadghole
