compiler warning in function with embedded assembly
Note: This was originally posted on 9th May 2012 at http://forums.arm.com
I'm using inline ARM assembly in C++ functions and I was wondering how to avoid "control reaches end of non-void function" warnings when my code is storing the final value in R0.
For example this function works fine, but the compiler will raise the warning:
int Math::test_iadd(int a, int B)
  __asm volatile
  "add r0, %0, %1   \n\t"
  : "r" (a), "r" (B)
  : "r0"
An easy fix is rewriting the function as:
int Math::test_iadd2(int a, int B)
int ret;
__asm volatile
  "add %0, %1, %2   \n\t"
  : "=r" (ret)
  : "r" (a), "r" (B)
  : "r0"
return ret;
But this shouldn't be required as the assembly generated by the compiler is basically the same code I use in the former function.
Any suggestion?
