Streamline - Bare Metal - Function/Call Paths view not showing function names
Hey! I am working on Streamline Performance Analyzer for Bare Metal Support.
Generated Barman files (Linear RAM Buffer) for cortex - R7 with 7 PMU counters, compiled them separately with armcc to create a library file.
My project code is also compiling with armcc and to enable the frame pointer, I have used --use_frame_pointer instead of --fno-fomit-frame-pointer as it is used for armclang.
The readings for PMU counters are visible in the timeline view, but the function view, call path view and code view are not showing function names rather only one function row with unknown_code_in_unresolved giving the complete 100% to its execution.
I am using ultimate version for DS-5.v5.28.1 for streamline.
Compiling my code on a different platform. Executing the .axf generated (after compiling) on my target and storing the buffer generated into a .raw file.
Does anyone know what is it that I am doing wrong?
Attached are the function and call path views   image.
