Hi guys,
Does anyone knows how I can try my bare-metal code generated by DS-5 Development Studio on a RPI 2 /3
I dont know which files I need to copy into the SD card of the RPI so I can test it. The bare-metal code is running on the DS-5 studio but I need to install and play with it on a RPI 2. Anyone that has done this before?
Thanks!
Below are a couple of resources you can look at. I'm not aware of any published information on DS-5, but will take a look and see if an example can be provided.
https://archive.fosdem.org/2017/schedule/event/programming_rpi3/
https://github.com/gingold-adacore/rpi3-fosdem17
The easiest way is to copy your bare-metal code to the SD card with the same name as the Linux image and it will run.
Thanks,
Jason
