ARMASM - include file using defined parameter
I trying to include .s file into another .s file using INCLUDE directive with defined parameter, but without success.
I check 2 scenario.
Scenario 1
startup.s file:
#include "Configuration.h"
#if defined (CONF_CHIP_ID_LPC1549JBD64)
	INCLUDE CONF_ARMHAL_STARTUPSFILE
... ; some asm code #endif
END
And "Configuration.h" file:
#define CONF_CHIP_ID_LPC1549JBD64    1
#define CONF_ARMHAL_STARTUPSFILE "..\..\..\ARM_HAL\startup_LPC15xx.s"
After compile I give an error:
.....\startup.s(17): error: A1023E: File ""..\..\..\ARM_HAL\startup_LPC15xx.s"" could not be opened: No such file or directory
- Please look at double quote at filename!
Scenario 2
In "Configuration.h" file, I was changed value of CONF_ARMHAL_STARTUPSFILE parameter, to without quote :
#define CONF_ARMHAL_STARTUPSFILE ..\..\..\ARM_HAL\startup_LPC15xx.s
....\startup.s(17): error: A1023E: File ". .\. .\. .\ARM_HAL\startup_LPC15xx . s" could not be opened: No such file or directory
- Please look at additional spaces in filename!
Please, what's wrong in C preprocessor? Is any way how to include file, defined by #define parameter?
Thank you.
This code is part of C project written in uVision IDE. Parameter "--cpreproc" is used for assembler.
ARMCC c5.06 update 5
ARMASM v5.06 update 5
  • Hi,
    Thank you for posting about the issue you are facing, and including an example to reproduce it.
    In Configuration.h, you have the following statement in Scenario 1:
    As per the documentation for the INCLUDE directive, you shouldn’t have double quotes around the file name. Therefore, you correctly changed it to the following line in Scenario 2:
    In this case, the C preprocessor will correctly add spaces around the . character as it is not within double quotes. To avoid this issue, you can use one of the following workarounds:
    • Insert the whitespace removal character sequence ## around each of the . characters in the path to the file. For example:
      .##.##\##.##.##\ARM_HAL\startup_LPC15xx##.##s
    • Alternatively, remove the relative path from the #define statement, add the whitespace removal character sequence ## around the remaining . character in the file name, and add the file include path to the armasm command-line option. For example, change the #define to:
      #define CONF_ARMHAL_STARTUPSFILE     startup_LPC15xx##.##s
      and use the following armasm command:
      armasm --cpreproc --cpu=Cortex-M4 -i "..\..\ARM_HAL" startup.s -o startup.o
    This should enable you to proceed building your project.
Reply Children
