Hello all,
I'm trying to compile my project using iar workbench. In my project I've used inline assembly and I'm having problem with executing an assembly instruction "ldr r1, =savebuffer" while trying to compile it shows syntax error. So I'm seeking for a solution here.
Note : using iar 8.20.1 with cortex m0+ as a target environment
Thanks in advance
Hi Saravanan,
As this discussion board tends to focus on the development tools from Arm, I can suggest that you give the Arm Compiler a try for your Cortex-M0+ project. Arm Compiler is available as part of DS-5 and Keil MDK https://developer.arm.com/products/software-development-tools/keil-mdk
Alternately, you might try the IAR website for support on the load instruction using their compiler.
Kind regards,
Elan
View all questions in Arm Compilers forum
