I'm new to ARM.
My use case: Ubuntu LAMP
I need to know how big is the memory footprint for system running 64-bit ARM processor compared to x86-64.
(Benchmark is really appreciated)
There's a recent paper on this sort of thing
Exploring the Limits of Code Density
in it you'll see ARM 64-bit is the densest code of any straightforward RISC - just go to the last green bar in the graphs and you'll see arm64 beneath it. It is still slightly less dense than x86-64. It is denser than ARM 32-bit code but quite a bit less dense than Thumb-2 code - but possibly the main gain of 32 bit code is the smaller address sizes in the data. I think those were produced using gcc 4 and there's been a number of small improvements in gcc 5.
Actual binaries for x86-64 tend to be often quite a bit larger but that is because they include all sorts of optional extras for ancient bits of legacy and changing instruction sets. If you're careful to compile them for the exact machine you're targeting the x86-64 should come down to about the same
Added
I see from their earlier paper they use icc for x86-64. This is better than gcc but I don't think it would make all that much difference for these tests.
I think the code density of the 64 bit ARM ISA is quite impressive especially considering they said that they were not concerned about the density of code when designing it.
View all questions in Arm Compilers forum
