Linker configuration from arm-none-eabi-gcc to ARMCC
I've a project which are started with arm-none-eabi-gcc and added in the last time the ARMCC. The linker configuration can't easy converted.
At the moment I search for a solution to define in the scatter file like the gcc linker file. This is used for the MPU configuration.
Here the content of my gcc linker file:
/* table of MPU sections */
.table.sections :
     . = ALIGN(4);
     LKF_SECTION_TABLE_START = .;
     LONG (__sec0_start)
     LONG (__sec0_end)
     LKF_SECTION_TABLE_END = .;
} > FLASH
/* MPU section 0 */
.sec0.data ALIGN(0x400)
     __sec0_start = .;
     *(.sec0_init)
     *sec0*.o(.data)
     . = ALIGN(4);
} > SRAM
.sec0.bss (NOLOAD) :
     *(.sec0)
     *sec0*.o(.bss COMMON)
     . = ALIGN(0x400);
     __sec0_end = .;
Now I need a solution for define the .table.sections in the ARMCC scatter file. The section is defined with:
sec0 AlignExpr(+0, 1024)  { .ANY(.sec0.data)  sec0*.o(+RW, +ZI) }
With the gcc can I read the .table.sectio with: extern uint32_t LKF_SECTION_TABLE_START[];
The using of the $$ variables in the C source code from the armlink is not so good. Have everybody a solution for definition of this table in the scatter file?
Thanks four Your help,
Bernd
