Hello. I am using ARMv8 foundation model for my project. When configure foundation model with multi cores (cores=4) my code does not run. Can you lease help me solve this problem?
I have not tried SP804 timer, but Linux kernel used architected timer and interrupts must work
even for booting the kernel. So yes, foundation model does generate interrupts.
Regards,
Sudeep
Hello Sudeep,
Yes. As u mentioned Foundation model does generates software interrupts in boot up time.
But i am not able to generate hardware interrupts. Can you please give me any example for generating hardware interrupts?
Thanks & Regards,
Jayashree P
I just boot Linux kernel(v4.7-rc2) on the Foundation model(v9.6).
Here is the cat /proc/interrupts output which shows many interrupts are
working including architected timers.
I haven't check SP804 yet. But why do you need that when you have both
sysreg and memory mapped architected timers working.
Hi Sudeep,
I have successfully boot linux 4.4-rc4 on the Foundation_Model using boot-wrappers but fail to wrapper the latest kernel 4.8-rc2 as it warns "FATAL ERROR: Unable to parse input tree". How to correctly boot the latest linux kernel (from git.kernel.org not linaro's) on Foundation_Model? Could you share your procedures and some boot arguments? Thank you very much!
Could you share more details on the model version and logs where you get the error.
I just tried mainline kernel(v4.8-rc2 and the tip as of today), both works (not done any
extensive testing but boots fine)
Well, kernel codes cloned from here (git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64.git) and boot-wrapper fetched from virtualopensystem (git://github.com/virtualopensystems/boot-wrapper.git) worked fine together. I could generate an axf file and boot it on Foundation Model embedded in DS-5 24.1. The foundation model here is build 9.6.43.
But after cross-compiling v4.8-rc2 codes, I wrap Image using boot-wrappers above mentioned, the output suggested a FATAL ERROR when parsing dts and I thought it was "dtc" executable that complained.
boot-wrapper git:(aarch64) ✗ make -f ./Makefile ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- \
BOOTARGS='"root=/dev/vda ip=dhcp rw console=ttyAMA0 maxcpus=1"' \
FDT_SRC=foundation-v8.dts IMAGE=image-foundation_img.axf
( echo "/include/ \"foundation-v8.dts\"" ; echo "/ { chosen { bootargs = \""root=/dev/vda ip=dhcp rw console=ttyAMA0 maxcpus=1"\"; }; };" ) | ./dtc -O dtb -o fdt.dtb -
Error: foundation-v8.dts:7.1-2 syntax error
Makefile:78: recipe for target 'fdt.dtb' failed
make: *** [fdt.dtb] Error 1
Yes, it's indeed dtc issue.
It could be more related to the path and how the files are included.
relative vs absolute paths ? Mainline kernel and boot-wrapper works out of box.
It could be some issue with that specific bootwrapper.
The bootwrapper now decompiles the one build in the kernel and modifies it.
( dtc -O dts -I dtb build/arch/arm64/boot/dts/arm/foundation-v8.dtb ; echo "/ { chosen { bootargs = \"root=/dev/vda1 rootwait consolelog=9 rw console=ttyAMA0; }; };" ) | dtc -O dtb -o fdt.dtb -
This specific wrapper deals with dts in almost the same way by using dts but dtb.
And FDT_SRC is assigned to foundation-v8.dts. So this specific wrapper seems to resemble the one you mentioned at least at this point. Actually I have adapted the common boot-wrapper to the new dts directory, still it failed and gave no error info.
I wonder if this booting method is rather old fashioned and out of favor, should I adopt Linaro's approach which could be found in Linaro's deliverables? Thank you so much!
View all questions in Arm Compilers forum
