Why cannot the cross-assembler work on this asm code?
I am working on assembler code with arm-linux-gnueabihf-as with a third part code project. I find that the assembler has errors:
> arm-linux-gnueabihf-as test_sp0.s
test_sp0.s: Assembler messages:
test_sp0.s:1: Error: junk at end of line, first unrecognized character is `='
test_sp0.s:3: Error: bad instruction `arm'
test_sp0.s:5: Error: bad instruction `area ||.text||,CODE,READONLY,ALIGN=2'
test_sp0.s:7: Error: bad instruction `export fl_array_m_ic32'
test_sp0.s:9: Error: bad instruction `input'
test_sp0.s:10: Error: bad instruction `r0 -p_i0_left'
test_sp0.s:11: Error: bad instruction `r1 -p_i0_right'
test_sp0.s:12: Error: bad instruction `r2 -p_i1_left'
test_sp0.s:13: Error: bad instruction `r3 -p_i1_right'
test_sp0.s:14: Error: bad instruction `sp -p_ot_left'
test_sp0.s:15: Error: bad instruction `sp +4-p_ot_right'
test_sp0.s:16: Error: bad instruction `sp +8-count'
test_sp0.s:17: Error: bad instruction `sp +12-shift'
test_sp0.s:19: Error: bad instruction `return'
test_sp0.s:20: Error: bad instruction `n/A'
test_sp0.s:22: Error: bad instruction `global Variables Accessed'
test_sp0.s:23: Error: bad instruction `none'
test_sp0.s:24: Error: bad instruction `cortex_a8'
for the code:
                    ARM
                    AREA ||.text||, CODE, READONLY, ALIGN=2
                    EXPORT  fl_array_m_ic32
;   Input
;   r0 - p_i0_left
;   r1 - p_i0_right
;   r2 - p_i1_left
;   r3 - p_i1_right
;   sp - p_ot_left
;   sp + 4  - p_ot_right
;   sp + 8  - count
;   sp + 12 - shift
;   Return
;   N/A
;   Global Variables Accessed
;   None
;;;;;;;;;;;;;;;;;;;;;;;;;;;;                    IF  :DEF:CORTEX_A8
fl_array_m_ic32     PROC
It is obvious that the assembler treats the comment char ';' as asm instruction. I used other compiler before, but not arm-linux-gnueabihf-as. From the asm code format, do you think what assembler can work on it? or are there some switches with arm-linux-gnueabihf-as to work on this asm code?
Thanks,
  • Assembler directives in the GNU assembler should also be prefixed by a dot.
    For instance ...
                        .include            "myfile.i"
    See also Useful assembler directives and macros for the GNU assembler for some hints.
    I think it's possible to write macros for the GNU assembler, which can 'emulate' ARMASM's assembler directives.
    Example:
                        .macro              EXPORT label:req,vararg:labels
                        .global            \label
                        .ifnb              '\labels'
                        EXPORT              \labels
                        .endif
                        .endm
    ... I think you should be able to reduce the above to the following, though:
                        .macro              EXPORT vararg:labels
                        .global            \labels
                        .endm
    For instance ...
                        .include            "myfile.i"
    Example:
                        .global            \label
                        .ifnb              '\labels'
                        EXPORT              \labels
                        .endif
                        .endm
                        .global            \labels
                        .endm
