Is NEON Floating Point (VFP) Only?
Referring to the diagram below, it appears that NEON only applies to floating point processing. Is this correct?
Does it mean that NEON only applies to using the VFP?
Does it mean that NEON does not apply to the Multiply, Shift, and ALU blocks in the diagram below?
