Hi Team,
As per the instructions below, I have done, but I am getting the below issue and attached screenshot Please suggest me.
Deploying cloud-based ML for speech transcription:
https://developer.arm.com/solutions/machine-learning-on-arm/developer-material/how-to-guides/deploying-cloud-based-ml-for-speech-transcription/before-you-begin
Error log:
Scanning dependencies of target allocatorScanning dependencies of target memcpyScanning dependencies of target dynload_warpctcScanning dependencies of target memory_block[ 10%] Building CXX object paddle/fluid/platform/dynload/CMakeFiles/dynload_warpctc.dir/warpctc.cc.o[ 10%] Building CXX object paddle/fluid/framework/CMakeFiles/attribute.dir/attribute.cc.oIn file included from /root/jay-paddle/Paddle/paddle/fluid/platform/cpu_info.cc:19:0:/root/jay-paddle/Paddle/build/third_party/install/xbyak/include/xbyak/xbyak_util.h:39:21: fatal error: cpuid.h: No such file or directorycompilation terminated.[ 10%] Building CXX object paddle/fluid/framework/CMakeFiles/prune.dir/prune.cc.opaddle/fluid/platform/CMakeFiles/cpu_info.dir/build.make:62: recipe for target 'paddle/fluid/platform/CMakeFiles/cpu_info.dir/cpu_info.cc.o' failedmake[2]: *** [paddle/fluid/platform/CMakeFiles/cpu_info.dir/cpu_info.cc.o] Error 1CMakeFiles/Makefile2:1891: recipe for target 'paddle/fluid/platform/CMakeFiles/cpu_info.dir/all' failedmake[1]: *** [paddle/fluid/platform/CMakeFiles/cpu_info.dir/all] Error 2make[1]: *** Waiting for unfinished jobs....[ 10%] Building CXX object paddle/fluid/memory/CMakeFiles/memcpy.dir/memcpy.cc.o[ 10%] Building CXX object paddle/fluid/memory/allocation/CMakeFiles/allocator.dir/allocator.cc.o[ 10%] Building CXX object paddle/fluid/memory/detail/CMakeFiles/memory_block.dir/memory_block_desc.cc.o[ 10%] Building CXX object paddle/fluid/memory/detail/CMakeFiles/memory_block.dir/memory_block.cc.o[ 10%] Building CXX object paddle/fluid/memory/detail/CMakeFiles/memory_block.dir/meta_cache.cc.o-- extern_cryptopp configure command succeeded. See also /root/jay-paddle/Paddle/build/third_party/cryptopp/src/extern_cryptopp-stamp/extern_cryptopp-configure-*.log[ 10%] Performing build step for 'extern_cryptopp'[ 98%] Built target cryptopp-object[ 99%] Built target cryptopp-static[100%] Built target cryptopp-shared[ 10%] Performing install step for 'extern_cryptopp'[ 10%] Linking CXX static library libdynload_warpctc.a-- extern_cryptopp install command succeeded. See also /root/jay-paddle/Paddle/build/third_party/cryptopp/src/extern_cryptopp-stamp/extern_cryptopp-install-*.log[ 10%] Built target dynload_warpctc[ 10%] Completed 'extern_cryptopp'[ 10%] Built target extern_cryptopp[ 10%] Linking CXX static library liballocator.a[ 10%] Linking CXX static library libmemcpy.a[ 10%] Built target allocator[ 10%] Built target memcpy[ 10%] Linking CXX static library libprofiler_proto.a[ 10%] Built target profiler_proto[ 11%] Linking CXX static library libattribute.a[ 11%] Linking CXX static library libmemory_block.a[ 11%] Built target attribute[ 11%] Built target memory_block[ 11%] Linking CXX static library libtrainer_desc_proto.a[ 11%] Built target trainer_desc_proto[ 11%] Linking CXX static library libprune.a[ 11%] Built target pruneMakefile:129: recipe for target 'all' failedmake: *** [all] Error 2
Thanks,Jay Prakash
JAY PRAKASH DUTTA said: fatal error: cpuid.h: No such file or directory
So have you checked if that file is actually present on your system at all ?
If it is present, have you correctly configured your Project to know where to find it ?
This is standard stuff:
www.avrfreaks.net/.../2774661
View all questions in Arm Compilers forum
