MacOS: objdump: Reading section .bss failed because: memory exhausted
Dear Community,
What does the error mean?
The error was introduced after a:  brew cask upgrade
The tools got updated from 7 to 9 -> arm-none-eabi-objdump --version
GNU objdump (GNU Tools for Arm Embedded Processors 9-2019-q4-major)
2.33.1.20191025
lib-h3 % arm-none-eabi-objdump -D lib_h3/libh3.a  |
arm-none-eabi-c++filt > lib_h3/lib.list
arm-none-eabi-objdump: error: lib_h3/libh3.a(h3_codec.o)(.bss) section size (0x800c bytes) is larger than file size (0xde8 bytes)
arm-none-eabi-objdump: Reading section .bss failed because: memory exhausted
arm-none-eabi-objdump: error: lib_h3/libh3.a(udp.o)(.bss) section size (0x19934 bytes) is larger than file size (0xcfc bytes)
lib-h3 % echo $?
0
lib-h3 % ls -al build_h3/src/h3_codec.o
-rwx------  1 arjanvanvught  staff  3560  7 apr 17:50 build_h3/src/h3_codec.o
The file size of the object file is 3560 bytes which is the (0xde8 bytes) as mentioned in the error. Why would there be an error or even better; why would there be any relationship between the allocated bytes in .bss and the object file size?
Many thanks in advance, Arjan
  • Hi,
    As Arjan and a.surati mentioned this was a bug introduced upstream when adding some hardening features to BFD.
    Essentially it's checking that the size in memory of a section isn't larger than it was on disk.
    But this needs to exclude purely synthetic sections such as `.bss` etc.
    I have fixed this in sourceware.org/.../show_bug.cgi and it was backported to 2.33 however the release was made after the fix.
    The next release of the GNU toolchain will contain the fix.
    Thanks,
    Tamar
  • Hi,
    Thanks,
    Tamar
