I am trying to use the ARM Compiler/Assembler 6 to assemble the alt_interrupt_aarch64.S that is part of the HWLIB for Intel/Altera SOCs. I used the Altera Evaluation License serial number and loaded it into the ARM license manager.
But when I try to use the ARM Assembler 6 I get an error that it cannot check out the license. Why is this happening?
10:20:43 **** Build of configuration Debug for project altera_hwlib **** make all 'Building file: ../alt_interrupt_aarch64.S' 'Invoking: Arm Assembler 6' armclang --target=aarch64-arm-none-eabi -mcpu=cortex-a53 -g -c -o "alt_interrupt_aarch64.o" "../alt_interrupt_aarch64.S" armclang.exe: error: Failed to check out a license. armclang.exe: note: Information about this error is available at: http://ds.arm.com/support/lic56/m103 General licensing information is available at: http://ds.arm.com/support/licensing/ If you need further help, provide this complete error report to your supplier or license.support@arm.com. - ARMLMD_LICENSE_FILE: 'C:\Users\ \AppData\Roaming\ARM\DS-5\licenses' - LM_LICENSE_FILE: unset - ARM_TOOL_VARIANT: 'eval_alt' - ARM_PRODUCT_PATH: 'C:\intelFPGA_pro\19.1\embedded\ds-5\sw\mappings' - Product location: C:\intelFPGA_pro\19.1\embedded\ds-5\sw\mappings - Toolchain location: C:\intelFPGA_pro\19.1\embedded\ds-5\sw\ARMCompiler6.10.1\lib\tt_default\bin - Selected tool variant: eval_alt armclang.exe: note: - Checkout feature: eval_alt_armcompiler - Feature version: 5.0201806 - Flex error code: -103 Product: DS-5 Intel SoC FPGA Edition 5.29.2 (Evaluation) Component: ARM Compiler 6.10.1 Tool: armclang [5d143200] make: *** [subdir.mk:17: alt_interrupt_aarch64.o] Error 1 10:20:43 Build Finished (took 157ms)
Hello, the evaluation license is only valid for 30 days. Has it expired? If you could share your license file, I can look at it for you.https://developer.arm.com/tools-and-software/embedded/legacy-tools/ds-5-development-studio/editions/customized-editions/intel-soc-fpga/evaluation-edition
View all questions in Arm Compilers forum
