Initialize C ++ object array in constructor?
I am facing issues with initialization of an object array within the Constructor. I would like to initialize my array using initialization from brace-enclosed lists. But the armcc compiler for some reason, doesn't compile my code nor throw me a warning!
For example, the array would be of "Component" type:
class Component
public:
    Component(const uint8_t componentValue);
private:
    const uint8_t ComponentValue;
Next, the "Device" class, would utilize the "Component" in an array.
class Device
public:
    Device();
private:
    Component components[3];
Now, within the Device.cpp, I try to initialize the array in the default constructor call as:
Device::Device()
    : components{Component(3),Component(4),Component(5)}
I have set my compilation flags to -cpp11. Also, this code compiles on a "arm-none-eabi-g++" compiler.
Why am I not able to compile this on armcc 5.06?
