Problem with rand_r() and strnlen()
I am currently currently using the ARM 6.6.1 compiler and running into an issue while using the rand_r() and strnlen() functions in the code below,
static inline uint32_t MCM_RandR(uint32_t *const aSeed)
    return rand_r((unsigned int*)aSeed);
This results in the following error:
      implicit declaration of function 'rand_r' is invalid in C99 [-Wimplicit-function-declaration]
Similarly I am running into a similar issue with the strnlen function which gives the below error when compiling,
      warning: implicit declaration of function 'strnlen' is invalid in C99 [-Wimplicit-function-declaration]
    len = strnlen(logBuf, ULOG_STR_MAX_SIZE);
The above code and both function calls compile fine with the ARM 6.6.2 compiler version, however with the 6.6.1 version I am getting the above errors.
Are these functions not supported in the 6.6.1 compiler as they are in 6.6.2? Are there any compiler options or settings that might enable their support in 6.6.1?
Would appreciate any feedback and thank you in advance for your help.
  • An "implicit declaration" means that you have failed to provide an explicit one; eg, a prototype  - which is usually due to a missing header file.
    So, in that version, see where those things are getting declared.
    Then look at the 6.6.1 version to see what's different ...
