Load Alignment Exception with Arm Compiler 6.13
I am working on a low level trusted bootloader (written in C) running on an ARM Cortex-A53 at EL3.  The MMU is not setup and the bootloader is running out of ROM.  We are linking in the CC712 TEE-SBROM library, and running into alignment exceptions when performing a load.  Prior to Arm compiler 6.13, I was able to force strict alignment using the -mno-unaligned-access.  The Alignment Data Abort Exception has returned with the 6.13.   More specifically, the exception happens when trying to initialize a local function variable:
char header[] = CC_SB_CERT_UTIL_PEM_HEADER; // value of pem header ends with "0x0a" == line feed
char footer[] = CC_SB_CERT_UTIL_PEM_FOOTER; // value of pem footer ends with "0x0a" == line feed
The constant string is stored at a 16-bit aligned address. When it tries to load the address, it generates an alignment exception.
Here's a snippet of the assembly:
# the address assigned (2-byte aligned)
EL3:0x000000000000E640 : ADRP     x8,{pc}+0x5000 ; 0x13640
EL3:0x000000000000E644 : ADD      x8,x8,#0x50a
# the load command
EL3:0x000000000000E668 : LDR      x12,[x8,#0]
Using ARM Compiler 6.12, the beginning of the string is placed on a 64-bit boundary. Any suggestions on how to do this on 6.13?
here are the compiler flags:
--target=aarch64-arm-none-eabi -mcpu=cortex-a53 -DARM_V8A -D__A53__ -D__64_BIT__ -DNO_MMU -c -DLITTLE__ENDIAN -DHASLONGLONG -Wall -Werror -Wno-self-assign -mno-unaligned-access -m -D__arm64__ -O0 -DDEBUG -g3
And the Exception:
ESR_EL3: 96000021  FAR_EL3: 1334a, Stack Ptr = 34077024
