I am trying to use C++ on a sample project for STM Nucleo board.
Language option on IAR project is basically C, but I wanted to try C++.
Here I could this by changing the option as:
From Project option - C/C++ Compiler - Language1 - Language - C
To Project option - C/C++ Compiler - Language1 - Language - C++
But, if I just choose Language - Auto ( extension-based) rather than C++,
compile errors happen although codes are the same :
Error[Pe020]: identifier "class" is undefined
Error[Pe065]: expected a ";"
Warning[Pe012]: parsing restarts here after previous syntax error
For C++ codes, I just included in the project class.cpp and class.h containing very simple C++ class.
I can't find any clue to solve this problem on the IAR website.
Please share your tips if you already experienced this before.
Thanks.
You need to ask IAR for support with their products!
https://www.iar.com/support/#!?tab=resources
View all questions in Arm Compilers forum
