ARM compiler upgrade from V5.06 to V6.10 failed
I try to upgrade ARM complier for V5.06 to V 6.10 in Keil MDK V5.26.
The projects I am mainly working for is with device STM32F407VGT6,
 the code like this:
typedef void (*const ISR)(void);
__attribute__ ((section("RESET"))) ISR IsrVector[]  =
    __initial_sp,                                   //Top of Stack
    Reset_Handler,                                 //Reset Handler
When I use ARM complier V 5.06, the link result is ok.
but when i use arm complier V6.10,I get this error:
  .\Objects\xxx.sct(7): error: L6236E: No section matches selector - no section to be FIRST/LAST.
Please advise me how to resovle this problem
