Whether Can ARM compiler 5 project call the library compiled by ARM compiler 6?
HI, all,
To optimize an algorith(coded by C) performance, I compiled the algorithm as  a library with ARM compiler 6.
But another problem appears that the library will be called by older ARM compiler 5 project.
I want to know:
1) Whether Can ARM compiler 5 project call library compiled by ARM compiler 6?
2) if 1) is ok, How to use the lib in ARM compiler 5 project ?
Regard!
