how to download and install free try Arm compiler 6?
Hello, you can get access to the compiler as part of Arm Development Studio, which has a free 30 day evaluation license available:https://developer.arm.com/tools-and-software/embedded/arm-development-studio/evaluate
Yeah, I have installed it. But When I compile using it . It shows this.
armclang -g -Wall -O1 main.c
armclang: error: Failed to check out a license.
The license file could not be found. Check that ARMLMD_LICENSE_FILE is set correctly.
Information about this error is available at: ds.arm.com/.../m1
General licensing information is available at: ds.arm.com/.../
If you need further help, provide this complete error report to your supplier or license.support@arm.com.
- ARMLMD_LICENSE_FILE: '/home/share/install_file/arm_compiler6/license_terms'
- LM_LICENSE_FILE: unset
- ARM_PRODUCT_DEF: unset
- ARM_PRODUCT_PATH: unset
- ARM_TOOL_VARIANT: unset
- Product location: /home/share/install_file/arm_compiler6/arm_compiler6_bin/sw/mappings
- Toolchain location: /home/share/install_file/arm_compiler6/arm_compiler6_bin/bin
- Selected tool variant: product
- Checkout feature: compiler5
- Feature version: 5.0201910
- Flex error code: -1
Product: ARM Compiler 6.13 Professional
Component: ARM Compiler 6.13
Tool: armclang [5d895a00]
You need to install an evaluation license... go to Help -> Arm license manager, and press "Add" to generate and set up the license.
Could you give me a website link?
Year, I want to know where is this "Help -> Arm license manager, and press "Add"". The arm website is too confusing. Some people agree with me.
This is inside the Development Studio IDE, not on a website
I don't want to install IDE if necessary. I download the arm compiler 6 in this link https://developer.arm.com/tools-and-software/embedded/arm-compiler/downloads/version-6. Then installed it, I don't know how to get license.
The Development Studio evaluation license is the default way to get the license.
I recommend you raise a support request to ask for a compiler only evaluation license.https://support.developer.arm.com/my-cases/open-case/
Thank you very much. :)
View all questions in Arm Compilers forum
