We have been trying to build with GNU ARM tool chain (Cortex-A specific tool) "gcc-arm-8.3-2019.03-i686-mingw32-arm-eabi", but we see the following error:
arm-eabi-gcc.exe error: CreateProcess: No such file or directory
Verified all the path settings and related python/GNUmake settings. Individual file compilation is proper. But this issue is observed when a batch build is triggered through make.
Any leads of suggestions would be helpful.
Thanks,Malli
Malli,
The issue you described has very little information for us to reproduce or diagnose. This error message presents usually when GCC is invoked but other dependant components are missing. I would suggest you to reinstall the tool package and set the path correctly.
Joey
View all questions in Arm Compilers forum
