I'm making XEN hypervisor being able to be built with ARM Compile 6 (6.6.3 in particular).
When built with GNU tools XEN hypervisor uses number of symbols defined in a linker script. E.g. [1].
Unfortunately, I did not find how to define symbols in a .scat file [2]. So tried employing steering file for symbols resolution to ARM Linker defined symbols.
Having only a steer file like [3], leads to errors like:
Error: L6280E: Cannot rename _start using the given patterns.Error: L6280E: Cannot rename _einittext using the given patterns.Error: L6280E: Cannot rename _etext using the given patterns.Error: L6280E: Cannot rename _stext using the given patterns.
I have two hacky solutions for the problem:
Any of those solutions is hardly acceptable. And leads to the problem with `symbols` tool used by XEN hypervisor for the final compilation.
Could you please suggest a way to resolve this issue?
View all questions in Arm Compilers forum
