ARM Linker defined symbols are not counted as referred from a steering file.
I'm making XEN hypervisor being able to be built with ARM Compile 6 (6.6.3 in particular).
When built with GNU tools XEN hypervisor uses number of symbols defined in a linker script. E.g. [1].
Unfortunately, I did not find how to define symbols in a .scat file [2]. So tried employing steering file for symbols resolution to ARM Linker defined symbols.
 Having only a steer file like [3], leads to errors like:
Error: L6280E: Cannot rename _start using the given patterns.
Error: L6280E: Cannot rename _einittext using the given patterns.
Error: L6280E: Cannot rename _etext using the given patterns.
Error: L6280E: Cannot rename _stext using the given patterns.
I have two hacky solutions for the problem:
  • Referring ARM linker defined symbols in a dummy code, then resolving them trough steering file [4]
  • Redefinition of required symbols to ARM linker defined symbols using macros [5].
Any of those solutions is hardly acceptable. And leads to the problem with `symbols` tool used by XEN hypervisor for the final compilation.
Could you please suggest a way to resolve this issue?
