Hello,I am trying to compile a very simple code that uses the function "aligned_alloc", using ARM Toolchain "gcc-arm-none-eabi-7" but every time I am receiving the error bellow
user@laptop:~/Downloads$ arm-none-eabi-gcc mem_align.c /opt/Xilinx/SDK/2018.3/gnu/aarch32/lin/gcc-arm-none-eabi/bin/../arm-none-eabi/libc/usr/lib/libc.a(lib_a-aligned_alloc.o): In function `aligned_alloc': aligned_alloc.c:(.text+0x14): undefined reference to `posix_memalign' /opt/Xilinx/SDK/2018.3/gnu/aarch32/lin/gcc-arm-none-eabi/bin/../arm-none-eabi/libc/usr/lib/libc.a(lib_a-exit.o): In function `exit': exit.c:(.text+0x2c): undefined reference to `_exit' /opt/Xilinx/SDK/2018.3/gnu/aarch32/lin/gcc-arm-none-eabi/bin/../arm-none-eabi/libc/usr/lib/libc.a(lib_a-sbrkr.o): In function `_sbrk_r': sbrkr.c:(.text+0x18): undefined reference to `_sbrk' /opt/Xilinx/SDK/2018.3/gnu/aarch32/lin/gcc-arm-none-eabi/bin/../arm-none-eabi/libc/usr/lib/libc.a(lib_a-writer.o): In function `_write_r': writer.c:(.text+0x24): undefined reference to `_write' /opt/Xilinx/SDK/2018.3/gnu/aarch32/lin/gcc-arm-none-eabi/bin/../arm-none-eabi/libc/usr/lib/libc.a(lib_a-closer.o): In function `_close_r': closer.c:(.text+0x18): undefined reference to `_close' /opt/Xilinx/SDK/2018.3/gnu/aarch32/lin/gcc-arm-none-eabi/bin/../arm-none-eabi/libc/usr/lib/libc.a(lib_a-fstatr.o): In function `_fstat_r': fstatr.c:(.text+0x20): undefined reference to `_fstat' /opt/Xilinx/SDK/2018.3/gnu/aarch32/lin/gcc-arm-none-eabi/bin/../arm-none-eabi/libc/usr/lib/libc.a(lib_a-isattyr.o): In function `_isatty_r': isattyr.c:(.text+0x18): undefined reference to `_isatty' /opt/Xilinx/SDK/2018.3/gnu/aarch32/lin/gcc-arm-none-eabi/bin/../arm-none-eabi/libc/usr/lib/libc.a(lib_a-lseekr.o): In function `_lseek_r': lseekr.c:(.text+0x24): undefined reference to `_lseek' /opt/Xilinx/SDK/2018.3/gnu/aarch32/lin/gcc-arm-none-eabi/bin/../arm-none-eabi/libc/usr/lib/libc.a(lib_a-readr.o): In function `_read_r': readr.c:(.text+0x24): undefined reference to `_read' collect2: error: ld returned 1 exit status
the code I am trying to compile is
#include <stdio.h> #include <stdlib.h> int main(void) { char *str = aligned_alloc(32, 256); printf("Data aligned: %p",(void*) str); return 0; }
Do you have any suggestion on how to fix the problem?Thank you,Thanos
View all questions in Arm Compilers forum
