I am currently working on composing a library. I have created .h file which is header file and .c file which has functions. How can ı link both these files. (I know that ı have to create object file but how?)
I can't figure if you are beginner to Arm Compiler trying to compiler your source files in your project to generate the final image or if you are looking to create a library from the generated objects.
If you are new to Arm Compiler and want to understand how to compile your project then the following link provides a nice tool flow diagram with a worked example to step-by-step compilation: Introduction to Arm Compiler 6
If you are looking to create a library of the generated objects, then you can use the armar utility: Overview of the Arm Librarian (armar).
Peterson
View all questions in Arm Compilers forum
