Hello;
I have a Cortex A9(NEON), Bare Metal(No Linux) project that has C and C++ codes together. I use DS-5 IDE and Arm Toolchain version 5 to build my project.
I decided to use Compute Library and make some performance tests. I need specifically basic operations like convolution, FFT, Transpose etc. For this purpose, I built Compute Library as static library using linaro toolchain from instructions for bare metal building and add it to my existing project as library file.
Problem is, When I Include Compute Library's NEON functions' header file, compiler complains about codes in the header files. It gaves lots of errors like '(' is expected here etc..
I suspect it is about C++ language versions but not sure.
So; is it possible to use Compute Library with a bare metal environment using Arm Compiler Toolchain 5 ? What should I do in order to use Compute Library in my way? Should I change my toolchain to which supports newer C++ language standarts?
Hello, I've never tried this with the Arm compiler, but you may find this documentation useful:https://arm-software.github.io/ComputeLibrary/v19.02/index.xhtml#S3_4_bare_metalI would recommend at least trying with Arm Compiler 6 (armclang), which is LLVM based, and so accepts more gnu-like constrructs than Arm Compiler 5 (armcc).
View all questions in Arm Compilers forum
