Pass in an immediate value to an inline assembly function
Note: This was originally posted on 6th March 2009 at http://forums.arm.com
I would like to pass in an immediate value to an inline assembly function, such as in this example:
inline int foo(int a, int b, const int immed)
   register int result;
   __asm
      add   result, a, b, lsl #immed
   return(result);
I am calling foo() with values of 5 or 6 for the immed operand, such as
z = foo(a, b, 5);
For the RVCT 3.0 armcc compiler, I get this error message for the immed operand: "Operand should be constant"
Is there any way to pass in the immediate value, which is known at compile time?
Note the analogous GCC version for the foo() definition has the additional syntax of "i"(immed) for the immediate operand, which allows for successful compilation.  That is, I don't have the problem for GCC.
