I am using the ARM clang tool chain version 6.10.1.
The linker is showing the following warning:
Warning: L6776W: The debug frame in .debug_frame(CHostComm.o) does not describe an executable section.
I have no idea why this is coming or how to solve the problem. Do I need to change the command line parameters for the linker or change something in my code?
Thank you for the feedback. I have been able to reproduce this issue and it will be resolved in a future release. As this is a warning, can you continue your project until we resolve the issue in the next release cycle?
This is benign warning which the arm linker emits as it finds debug info which has references to an "invalid group" section. This generally happens when you code using C++ templates, the armclang organizes the code for each template iinto different groups but doesn't put the respective debug info in the same group. So if one group gets removed it leaves behind the debug info which references code from an invalid group. armclang does not produce a separate .debug_frame section for each group and hence the linker issues this warning.
We are able to reproduce this scenario and it will be resolved in a future release. Since this is a warning, you can suppress it by passing "--diag_suppress L6776W" as a linker flag which will allow you to continue with your project.
Let me know if you are still having problems.
Peterson
I am also getting the following warning:
Warning: L6439W: Multiply defined Global Symbol OMNullValue<unsigned char>::get()::nullSet defined in invalid_group(CHostComm.o) rejected in favor of Symbol defined in .bss._ZZN11OMNullValueIhE3getEvE7nullSet(PKG_G_FirmwareUpdate.o).
Is this a similar bug? It also has to do with templates and invalid groups.
Apologies since you ran into warnings again.
In this case, the "L6439W" warning is the same as "L6776W" in a slightly different shade.
The background is the same as explained for L6776W, where there is a symbol defined in a comdat group in two input files and the linker first selects a group from the first file but later decides to instead use a group from the second file because it is smaller or more efficient. In that case, the linker ends up with two definitions of this symbol from both groups and reported a warning about it.
This is mainly the order in which the objects are provided to the linker. Sometimes reordering the sequence in which the objects are consumed into the linker can help as the linker would spot the optimised group first then it when it encounters the group from another file it will recognise if it has selected the correct one and not fall into this situation. However we can't always control the of some objects as they come from the library and hence could run into the same again.
This is a harmless warning and should not hamper your development. We did already pick this up in our internal testing and a fix for it is on the way. We aim to have both warnings resolved in the next release which is targeted at the end of October.
I hope this has not caused you any inconvenience and you can progress further with your development.
Best regards,
Hi Peterson
You sent me a privat message, but I cannot reply to it as the return address is <noreply@arm.com>. Can you send me an email address to reply to you. I do not want to publish the answer to your questions here.
I have connected with you and sent you my email. Please get in touch.
View all questions in Arm Compilers forum
