Are there any machine learning libraries in C#? I'm after something like WEKA.
  • Hi Emma, Mlpack is a fast, flexible machine learning library, written in C++. The library aims to provide fast, extensible implementations of cutting-edge machine learning algorithms.
    Regards,
    Kevin J. Hodge Tutuapp Vidmate
  • Yes, there are machine learning libraries in c#. C# is one of the most versatile programming languages in the world. It allows developers to build all kinds of applications including Windows clients, consoles, Web apps, mobile apps, and backend systems. C# can be used for machine learning applications via a. NET Core machine learning platform, ML.NE.
    If you wants to clear your doubts in machine learning i have an advice for you just go through geeksforgeeks here you can clear your all doubts in deep level, thay also have different courses, you can join them easily. I also use geeksforgeeks for my all doubts.
There are no posts to show. This could be because there are no posts in this forum or due to a filter.
