I want to load a Tensorflow model on my ARM-device. The model is rather simple:
Layer (type) Output Shape Param #=================================================================conv2d (Conv2D) (None, 1, 32, 8) 120_________________________________________________________________re_lu (ReLU) (None, 1, 32, 8) 0_________________________________________________________________conv2d_1 (Conv2D) (None, 1, 32, 4) 32_________________________________________________________________re_lu_1 (ReLU) (None, 1, 32, 4) 0_________________________________________________________________max_pooling2d (MaxPooling2D) (None, 1, 16, 4) 0_________________________________________________________________conv2d_2 (Conv2D) (None, 1, 8, 16) 320_________________________________________________________________re_lu_2 (ReLU) (None, 1, 8, 16) 0_________________________________________________________________conv2d_3 (Conv2D) (None, 1, 8, 8) 128_________________________________________________________________re_lu_3 (ReLU) (None, 1, 8, 8) 0_________________________________________________________________max_pooling2d_1 (MaxPooling2 (None, 1, 4, 8) 0_________________________________________________________________conv2d_4 (Conv2D) (None, 1, 1, 8) 264_________________________________________________________________re_lu_4 (ReLU) (None, 1, 1, 8) 0_________________________________________________________________conv2d_5 (Conv2D) (None, 1, 1, 2) 18_________________________________________________________________flatten (Flatten) (None, 2) 0=================================================================
I trained the model using Keras + Tesnorflow 1.13.1 and used the same Tensorflow version during the build process of ArmNN. The model is stored in a Keras model file (HDF5) and then converted into an binary Tensorflow model (.pb) using the save_model function.
Unfortunately, I am not able to the model and get the following error message:
'Unsupported operation Max in tensorflow::GraphDef at function LoadNodeDef [/armnn/armnn-19.02/src/armnnTfParser/TfParser.cpp:3237]'
Since i dont use any uncommon Layers I am a little bit supprised. Loading the MNIST example model (simple_mnist_tf.pb) works fine.
Is their any option i have to pay attention when saving the model? Or is their any documentation about that topic?
Thanks in advance!
Gerald
View all questions in Machine Learning forum
