hi
im trying to pipe a proprietry model using arm compute library, looking at the examples in the examples folder, couldn't find how to set dilation in ConvolutionLayer() routine
here is an example i saw:
ConvolutionLayer( 7U, 7U, 64U, get_weights_accessor(data_path, "/cnn_data/resnet50_model/conv1_weights.npy"), std::unique_ptr<arm_compute::graph::ITensorAccessor>(nullptr), PadStrideInfo(2, 2, 3, 3)) .set_name("conv1/convolution")where to set dilation?thanks!
gilboash Compute Library graph is mainly used for internal integration test, please use Arm NN graph instead. Dilated convolution is supported at function level for Compute Library https://github.com/ARM-software/ComputeLibrary/blob/master/arm_compute/runtime/CL/functions/CLConvolutionLayer.h#L60.
View all questions in Machine Learning forum
