I tried to execute Smart mic project with KWS (real time) example as given in "Smart mic - "">www.st.com/.../fp-aud-smartmic1.html" and KWS - "">github.com/.../ML-KWS-for-MCU". I got some issue in detection. Here ,I used STM32F769NI Evaluation board. There was random detection, not getting proper keyword detection. I assured that my Mic output data is right(checked on AUDACITY) , but not detect keyword using KWS ( detect random index of keyword string). My audio_buffer_In input size is (2560). recording window 3, frame_shift 320. Where i was wrong ? Which steps i have to follow for proper keyword detection ? my detection routine in main is as follows: when come into main below function i called:
kws = new KWS_F769NI(recording_win, averaging_window_len); // detection started in while loop while(1) { if(BufferState == 1) //state comes when audio_buffer_In filled with data size 2560/2 i.e 80msec audio { BufferState = 0; if(kws->frame_len!=kws->frame_shift) //copy the last (frame_len - frame_shift) audio data to the start { arm_copy_q7((q7_t )(kws->audio_buffer)+2(kws->audio_buffer_size-(kws->frame_len-kws->frame_shift)), (q7_t )kws->audio_buffer, 2(kws->frame_len- kws->frame_shift)); } // copy the new recording data for (int i=0;iaudio_block_size;i++) { kws->audio_buffer[kws->frame_len-kws->frame_shift+i] = audio_buffer_In [i*2]; } run_kws(); else { if(BufferState == 2) //state comes when audio_buffer_In filled with data size 2560/2 i.e 80msec audio data { BufferState = 0; if(kws->frame_len != kws->frame_shift) //copy the last (frame_len - frame_shift) audio data to the start { memmove((q7_t )(kws->audio_buffer)+2(kws->audio_buffer_size-(kws->frame_len-kws->frame_shift)), (q7_t )kws->audio_buffer, 2(kws->frame_len-kws- >frame_shift)); } // copy the new recording data for (int i=0;iaudio_block_size;i++){ kws->audio_buffer[kws->frame_len-kws->frame_shift+i] = audio_buffer_In [2kws- >audio_block_size+i2]; } }
View all questions in Machine Learning forum
