I have a confusion regarding GNU compiler licesnce. I gone through GNU ARM Embedded Toolchain license and noticed it has built with "newlib" C standard library instead of glibc to avoid licensing issue.
But still i want to clarify my confusion for below questions
1. Let's say i have a permissive BSD licensed opensource code, which i want to compile and put the outcome binary into commerical product. For this can i use GNU ARM Embedded Toolchain for compilation?
- Compiler adds some symbols sometimes into binary, example unwind related symbol, does it have any licensing issue?
- Is is statically linking is okay? because binary might need library symbols from toolchain.
Please some clarify.
Hello Manohara,
have you found the answer so far?
Currently I face the same problem. I wold like to use GNU ARM Embedded Toolchain to compile commercial product (sell the programmed device, no opensource). I thing compiling is ok, but there is problem with libraries. There is an exception from GPL for runtime libraries, which i guess is libgcc. The part about runtime library is not much clear to me. Is libc a runtime library or not? What about libm, libstdc++ and others?
View all questions in GNU Toolchain forum
