Dear Sir,
How to disable floating-point instruction generation with aarch64 GCC compiler ?
We want to use software to do floating-point calculation.
But always has error messages as below:
aarch64-linux-gnu-gcc -mcpu=cortex-a53+nofp test.ctest.c: In function 'main':test.c:24:11: error: '+nofp' feature modifier is incompatible with floating-point code float aa = 0.0; ^test.c:28:12: error: '+nofp' feature modifier is incompatible with floating-point argument aa += 3.0; ^test.c:28:12: error: '+nofp' feature modifier is incompatible with floating-point argumenttest.c:28:12: error: '+nofp' feature modifier is incompatible with floating-point codetest.c:28: confused by earlier errors, bailing out
Any suggestion is good.
Thank you.
test.c
#include <stdlib.h>#include <stdio.h>
/* * void main(void) * the application start point for the primary CPU * * Inputs * <none> * * Returns * subroutine does not return */int main(void){ float aa = 0.0; int i;
for(i = 0; i < 1024; i++) { aa += 3.0; }
if (aa > 1000.0) exit(1); else exit(2);
return 0;}
nofp means no floating point at all, it is used to check floating point isn't used by mistake in some place it might cause problems like a device driver. The gcc option you want is -msoft-float, however this is not supported in any build for Aarch64 currently, it is really there for embedded processors that don't support a floating point unit. It wouldn't be hard to support in gcc- but it would require all associated libraries be built with the option as well and that implies a lot of support effort.
Thank you for your explanation.
View all questions in GNU Toolchain forum
