cross compile "EB_TrustZone_Example" using "arm-none-eabi-gcc"
I am trying to cross compile "EB_TrustZone_Example" using "arm-none-eabi-gcc"
Modified "#__smc(0) void yeild(void);" with "__asm__(" smc #0");" in main_normal.c
I have followed the following steps to compile.
arm-none-eabi-gcc  -c --debug -mcpu=cortex-a5 -O1 -o ./obj/main_normal.o  ./src/main_normal.c
arm-none-eabi-gcc  -c --debug -mcpu=cortex-a5 -O1 -o ./obj/retarget_normal.o  ./src/retarget_normal.c
arm-none-eabi-as -mcpu=cortex-a5 -o obj/startup_normal.o src/startup_normal.s
arm-none-eabi-as -mcpu=cortex-a5 -o obj/v7.o src/v7.s
When I try to compile v7.s I am getting the following errors as shown below:
src/v7.s: Assembler messages:
src/v7.s:1: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:2: Error: bad instruction `v7-A Cache and Branch Prediction Maintenance Operations'
src/v7.s:3: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:5: Error: bad instruction `preserve8 '
src/v7.s:7: Error: bad instruction `area v7Opps,CODE,READONLY'
src/v7.s:9: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:10: Error: bad instruction `interrupt enable/disable'
src/v7.s:11: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:13: Error: bad instruction `could use intrinsic instead of these'
src/v7.s:15: Error: bad instruction `export enableInterrupts'
src/v7.s:16: Error: bad instruction `void enableInterrupts(void)'
src/v7.s:17: Error: bad instruction `enableinterrupts PROC'
src/v7.s:20: Error: bad instruction `endp '
src/v7.s:22: Error: bad instruction `export disableInterrupts'
src/v7.s:23: Error: bad instruction `void disableInterrupts(void)'
src/v7.s:24: Error: bad instruction `disableinterrupts PROC'
src/v7.s:27: Error: bad instruction `endp '
src/v7.s:29: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:30: Error: bad instruction `cache Maintenance'
src/v7.s:31: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:33: Error: bad instruction `export enableCaches'
src/v7.s:34: Error: bad instruction `void enableCaches(void)'
src/v7.s:35: Error: bad instruction `enablecaches PROC'
src/v7.s:36: Error: bad instruction `read System Control Register configuration data'
src/v7.s:37: Error: bad instruction `set C bit'
src/v7.s:38: Error: bad instruction `set I bit'
src/v7.s:39: Error: bad instruction `write System Control Register configuration data'
src/v7.s:41: Error: bad instruction `endp '
src/v7.s:44: Error: bad instruction `export disableCaches'
src/v7.s:45: Error: bad instruction `void disableCaches(void)'
src/v7.s:46: Error: bad instruction `disablecaches PROC'
src/v7.s:47: Error: bad instruction `read System Control Register configuration data'
src/v7.s:48: Error: bad instruction `clear C bit'
src/v7.s:49: Error: bad instruction `clear I bit'
src/v7.s:50: Error: bad instruction `write System Control Register configuration data'
src/v7.s:52: Error: bad instruction `endp '
src/v7.s:55: Error: bad instruction `export cleanDCache'
src/v7.s:56: Error: bad instruction `void cleanDCache(void)'
src/v7.s:57: Error: bad instruction `cleandcache PROC'
src/v7.s:61: Error: bad instruction `based on code example given in section 11.2.4 of ARM DDI 0406B'
src/v7.s:64: Error: bad instruction `read CLIDR'
src/v7.s:66: Error: bad instruction `cache level value(naturally aligned)'
src/v7.s:70: Error: bad instruction `clean_dcache_loop1 '
src/v7.s:71: Error: bad instruction `work out 3xcachelevel'
src/v7.s:72: Error: bad instruction `bottom 3 bits are the Cache type for this level'
src/v7.s:73: Error: bad instruction `get those 3 bits alone'
src/v7.s:75: Error: bad instruction `no cache or only instruction cache at this level'
src/v7.s:76: Error: bad instruction `write the Cache Size selection register'
src/v7.s:77: Error: invalid barrier type -- `isb to sync the change to the CacheSizeID reg'
src/v7.s:78: Error: bad instruction `reads current Cache Size ID register'
src/v7.s:79: Error: bad instruction `extract the line length field'
src/v7.s:80: Error: ARM register expected -- `add 4 for the line length offset(log2 16 bytes)'
src/v7.s:82: Error: bad instruction `r4 is the max number on the way size(right aligned)'
src/v7.s:83: Error: bad instruction `r5 is the bit position of the way size increment'
src/v7.s:85: Error: bad instruction `r7 is the max number of the index size(right aligned)'
src/v7.s:87: Error: bad instruction `clean_dcache_loop2 '
src/v7.s:88: Error: bad instruction `r9 working copy of the max way size(right aligned)'
src/v7.s:90: Error: bad instruction `clean_dcache_loop3 '
src/v7.s:91: Error: bad instruction `factor in the way number and cache number into R11'
src/v7.s:92: Error: bad instruction `factor in the index number'
src/v7.s:93: Error: bad instruction `dccsw -clean by set/way'
src/v7.s:94: Error: bad instruction `decrement the way number'
src/v7.s:96: Error: bad instruction `decrement the index'
src/v7.s:99: Error: bad instruction `clean_dcache_skip '
src/v7.s:100: Error: bad instruction `increment the cache number'
src/v7.s:104: Error: bad instruction `clean_dcache_finished '
src/v7.s:108: Error: bad instruction `endp '
src/v7.s:110: Error: bad instruction `export cleanInvalidateDCache'
src/v7.s:111: Error: bad instruction `void cleanInvalidateDCache(void)'
src/v7.s:112: Error: bad instruction `cleaninvalidatedcache PROC'
src/v7.s:116: Error: bad instruction `based on code example given in section 11.2.4 of ARM DDI 0406B'
src/v7.s:119: Error: bad instruction `read CLIDR'
src/v7.s:121: Error: bad instruction `cache level value(naturally aligned)'
src/v7.s:125: Error: bad instruction `clean_invalidate_dcache_loop1 '
src/v7.s:126: Error: bad instruction `work out 3xcachelevel'
src/v7.s:127: Error: bad instruction `bottom 3 bits are the Cache type for this level'
src/v7.s:128: Error: bad instruction `get those 3 bits alone'
src/v7.s:130: Error: bad instruction `no cache or only instruction cache at this level'
src/v7.s:131: Error: bad instruction `write the Cache Size selection register'
src/v7.s:132: Error: invalid barrier type -- `isb to sync the change to the CacheSizeID reg'
src/v7.s:133: Error: bad instruction `reads current Cache Size ID register'
src/v7.s:134: Error: bad instruction `extract the line length field'
src/v7.s:135: Error: ARM register expected -- `add 4 for the line length offset(log2 16 bytes)'
src/v7.s:137: Error: bad instruction `r4 is the max number on the way size(right aligned)'
src/v7.s:138: Error: bad instruction `r5 is the bit position of the way size increment'
src/v7.s:140: Error: bad instruction `r7 is the max number of the index size(right aligned)'
src/v7.s:142: Error: bad instruction `clean_invalidate_dcache_loop2 '
src/v7.s:143: Error: bad instruction `r9 working copy of the max way size(right aligned)'
src/v7.s:145: Error: bad instruction `clean_invalidate_dcache_loop3 '
src/v7.s:146: Error: bad instruction `factor in the way number and cache number into R11'
src/v7.s:147: Error: bad instruction `factor in the index number'
src/v7.s:148: Error: bad instruction `dccisw -clean and invalidate by set/way'
src/v7.s:149: Error: bad instruction `decrement the way number'
src/v7.s:151: Error: bad instruction `decrement the index'
src/v7.s:154: Error: bad instruction `clean_invalidate_dcache_skip '
src/v7.s:155: Error: bad instruction `increment the cache number'
src/v7.s:159: Error: bad instruction `clean_invalidate_dcache_finished '
src/v7.s:163: Error: bad instruction `endp '
src/v7.s:166: Error: bad instruction `export invalidateCaches'
src/v7.s:167: Error: bad instruction `void invalidateCaches(void)'
src/v7.s:168: Error: bad instruction `invalidatecaches PROC'
src/v7.s:172: Error: bad instruction `based on code example given in section B2.2.4/11.2.4 of ARM DDI 0406B'
src/v7.s:176: Error: bad instruction `iciallu -Invalidate entire I Cache,and flushes branch target cache'
src/v7.s:178: Error: bad instruction `read CLIDR'
src/v7.s:180: Error: bad instruction `cache level value(naturally aligned)'
src/v7.s:184: Error: bad instruction `invalidate_caches_loop1 '
src/v7.s:185: Error: bad instruction `work out 3xcachelevel'
src/v7.s:186: Error: bad instruction `bottom 3 bits are the Cache type for this level'
src/v7.s:187: Error: bad instruction `get those 3 bits alone'
src/v7.s:189: Error: bad instruction `no cache or only instruction cache at this level'
src/v7.s:190: Error: bad instruction `write the Cache Size selection register'
src/v7.s:191: Error: invalid barrier type -- `isb to sync the change to the CacheSizeID reg'
src/v7.s:192: Error: bad instruction `reads current Cache Size ID register'
src/v7.s:193: Error: bad instruction `extract the line length field'
src/v7.s:194: Error: ARM register expected -- `add 4 for the line length offset(log2 16 bytes)'
src/v7.s:196: Error: bad instruction `r4 is the max number on the way size(right aligned)'
src/v7.s:197: Error: bad instruction `r5 is the bit position of the way size increment'
src/v7.s:199: Error: bad instruction `r7 is the max number of the index size(right aligned)'
src/v7.s:201: Error: bad instruction `invalidate_caches_loop2 '
src/v7.s:202: Error: bad instruction `r9 working copy of the max way size(right aligned)'
src/v7.s:204: Error: bad instruction `invalidate_caches_loop3 '
src/v7.s:205: Error: bad instruction `factor in the way number and cache number into R11'
src/v7.s:206: Error: bad instruction `factor in the index number'
src/v7.s:207: Error: bad instruction `dcisw -invalidate by set/way'
src/v7.s:208: Error: bad instruction `decrement the way number'
src/v7.s:210: Error: bad instruction `decrement the index'
src/v7.s:213: Error: bad instruction `invalidate_caches_skip '
src/v7.s:214: Error: bad instruction `increment the cache number'
src/v7.s:218: Error: bad instruction `invalidate_caches_finished '
src/v7.s:221: Error: bad instruction `endp '
src/v7.s:224: Error: bad instruction `export invalidateCaches_IS'
src/v7.s:225: Error: bad instruction `void invalidateCaches_IS(void)'
src/v7.s:226: Error: bad instruction `invalidatecaches_is PROC'
src/v7.s:230: Error: bad instruction `icialluis -Invalidate entire I Cache inner shareable'
src/v7.s:232: Error: bad instruction `read CLIDR'
src/v7.s:234: Error: bad instruction `cache level value(naturally aligned)'
src/v7.s:238: Error: bad instruction `invalidate_caches_is_loop1 '
src/v7.s:239: Error: bad instruction `work out 3xcachelevel'
src/v7.s:240: Error: bad instruction `bottom 3 bits are the Cache type for this level'
src/v7.s:241: Error: bad instruction `get those 3 bits alone'
src/v7.s:243: Error: bad instruction `no cache or only instruction cache at this level'
src/v7.s:244: Error: bad instruction `write the Cache Size selection register'
src/v7.s:245: Error: invalid barrier type -- `isb to sync the change to the CacheSizeID reg'
src/v7.s:246: Error: bad instruction `reads current Cache Size ID register'
src/v7.s:247: Error: bad instruction `extract the line length field'
src/v7.s:248: Error: ARM register expected -- `add 4 for the line length offset(log2 16 bytes)'
src/v7.s:250: Error: bad instruction `r4 is the max number on the way size(right aligned)'
src/v7.s:251: Error: bad instruction `r5 is the bit position of the way size increment'
src/v7.s:253: Error: bad instruction `r7 is the max number of the index size(right aligned)'
src/v7.s:255: Error: bad instruction `invalidate_caches_is_loop2 '
src/v7.s:256: Error: bad instruction `r9 working copy of the max way size(right aligned)'
src/v7.s:258: Error: bad instruction `invalidate_caches_is_loop3 '
src/v7.s:259: Error: bad instruction `factor in the way number and cache number into R11'
src/v7.s:260: Error: bad instruction `factor in the index number'
src/v7.s:261: Error: bad instruction `dcisw -clean by set/way'
src/v7.s:262: Error: bad instruction `decrement the way number'
src/v7.s:264: Error: bad instruction `decrement the index'
src/v7.s:267: Error: bad instruction `invalidate_caches_is_skip '
src/v7.s:268: Error: bad instruction `increment the cache number'
src/v7.s:272: Error: bad instruction `invalidate_caches_is_finished '
src/v7.s:275: Error: bad instruction `endp '
src/v7.s:277: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:278: Error: bad instruction `tlb '
src/v7.s:279: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:281: Error: bad instruction `export invalidateUnifiedTLB'
src/v7.s:282: Error: bad instruction `void invalidateUnifiedTLB(void)'
src/v7.s:283: Error: bad instruction `invalidateunifiedtlb PROC'
src/v7.s:285: Error: bad instruction `tlbiall -Invalidate entire unified TLB'
src/v7.s:287: Error: bad instruction `endp '
src/v7.s:289: Error: bad instruction `export invalidateUnifiedTLB_IS'
src/v7.s:290: Error: bad instruction `void invalidateUnifiedTLB_IS(void)'
src/v7.s:291: Error: bad instruction `invalidateunifiedtlb_is PROC'
src/v7.s:293: Error: bad instruction `tlbiallis -Invalidate entire unified TLB Inner Shareable'
src/v7.s:295: Error: bad instruction `endp '
src/v7.s:297: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:298: Error: bad instruction `branch Prediction'
src/v7.s:299: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:301: Error: bad instruction `export enableBranchPrediction'
src/v7.s:302: Error: bad instruction `void enable_branch_prediction(void)'
src/v7.s:303: Error: bad instruction `enablebranchprediction PROC'
src/v7.s:304: Error: bad instruction `read SCTLR'
src/v7.s:305: Error: bad instruction `set the Z bit(bit 11)'
src/v7.s:306: Error: bad instruction `write SCTLR'
src/v7.s:308: Error: bad instruction `endp '
src/v7.s:310: Error: bad instruction `export disableBranchPrediction'
src/v7.s:311: Error: bad instruction `void disableBranchPrediction(void)'
src/v7.s:312: Error: bad instruction `disablebranchprediction PROC'
src/v7.s:313: Error: bad instruction `read SCTLR'
src/v7.s:314: Error: bad instruction `clear the Z bit(bit 11)'
src/v7.s:315: Error: bad instruction `write SCTLR'
src/v7.s:317: Error: bad instruction `endp '
src/v7.s:319: Error: bad instruction `export flushBranchTargetCache'
src/v7.s:320: Error: bad instruction `void flushBranchTargetCache(void)'
src/v7.s:321: Error: bad instruction `flushbranchtargetcache PROC'
src/v7.s:323: Error: bad instruction `bpiall -Invalidate entire branch predictor array'
src/v7.s:325: Error: bad instruction `endp '
src/v7.s:327: Error: bad instruction `export flushBranchTargetCache_IS'
src/v7.s:328: Error: bad instruction `void flushBranchTargetCache_IS(void)'
src/v7.s:329: Error: bad instruction `flushbranchtargetcache_is PROC'
src/v7.s:331: Error: bad instruction `bpiallis -Invalidate entire branch predictor array Inner Shareable'
src/v7.s:333: Error: bad instruction `endp '
src/v7.s:335: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:336: Error: bad instruction `high Vecs'
src/v7.s:337: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:339: Error: bad instruction `export enableHighVecs'
src/v7.s:340: Error: bad instruction `void enableHighVecs(void)'
src/v7.s:341: Error: bad instruction `enablehighvecs PROC'
src/v7.s:342: Error: bad instruction `read Control Register'
src/v7.s:343: Error: bad instruction `set the V bit(bit 13)'
src/v7.s:344: Error: bad instruction `write Control Register'
src/v7.s:346: Error: bad instruction `endp '
src/v7.s:348: Error: bad instruction `export disableHighVecs'
src/v7.s:349: Error: bad instruction `void disable_highvecs(void)'
src/v7.s:350: Error: bad instruction `disablehighvecs PROC'
src/v7.s:351: Error: bad instruction `read Control Register'
src/v7.s:352: Error: bad instruction `clear the V bit(bit 13)'
src/v7.s:353: Error: bad instruction `write Control Register'
src/v7.s:355: Error: bad instruction `endp '
src/v7.s:357: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:358: Error: bad instruction `context ID'
src/v7.s:359: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:361: Error: bad instruction `export getContextID'
src/v7.s:362: Error: bad instruction `uint32_t getContextIDd(void)'
src/v7.s:363: Error: bad instruction `getcontextid PROC'
src/v7.s:364: Error: bad instruction `read Context ID Register'
src/v7.s:366: Error: bad instruction `endp '
src/v7.s:368: Error: bad instruction `export setContextID'
src/v7.s:369: Error: bad instruction `void setContextID(uint32_t)'
src/v7.s:370: Error: bad instruction `setcontextid PROC'
src/v7.s:371: Error: bad instruction `write Context ID Register'
src/v7.s:373: Error: bad instruction `endp '
src/v7.s:375: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:376: Error: bad instruction `id registers'
src/v7.s:377: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:379: Error: bad instruction `export getMIDR'
src/v7.s:380: Error: bad instruction `uint32_t getMIDR(void)'
src/v7.s:381: Error: bad instruction `getmidr PROC'
src/v7.s:382: Error: bad instruction `read Main ID Register(MIDR)'
src/v7.s:384: Error: bad instruction `endp '
src/v7.s:386: Error: bad instruction `export getMPIDR'
src/v7.s:387: Error: bad instruction `uint32_t getMPIDR(void)'
src/v7.s:388: Error: bad instruction `getmpidr PROC'
src/v7.s:389: Error: bad instruction `read Multiprocessor ID register(MPIDR)'
src/v7.s:391: Error: bad instruction `endp '
src/v7.s:393: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:394: Error: bad instruction `cp15 SMP related'
src/v7.s:395: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:397: Error: bad instruction `export getBaseAddr'
src/v7.s:398: Error: bad instruction `uint32_t getBaseAddr(void)'
src/v7.s:399: Error: bad instruction `returns the value CBAR(base address of the private peripheral memory space)'
src/v7.s:400: Error: bad instruction `getbaseaddr PROC'
src/v7.s:401: Error: bad instruction `read periph base address(see DE593076)'
src/v7.s:403: Error: bad instruction `endp '
src/v7.s:405: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:407: Error: bad instruction `export getCPUID'
src/v7.s:408: Error: bad instruction `uint32_t getCPUID(void)'
src/v7.s:409: Error: bad instruction `returns the CPU ID(0 to 3)of the CPU executed on'
src/v7.s:410: Error: bad instruction `getcpuid PROC'
src/v7.s:411: Error: bad instruction `read CPU ID register'
src/v7.s:412: Error: bad instruction `mask off,leaving the CPU ID field'
src/v7.s:414: Error: bad instruction `endp '
src/v7.s:416: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:418: Error: bad instruction `export goToSleep'
src/v7.s:419: Error: bad instruction `void goToSleep(void)'
src/v7.s:420: Error: bad instruction `gotosleep PROC'
src/v7.s:421: Error: bad instruction `go into standby'
src/v7.s:422: Error: bad instruction `catch in case of rogue events'
src/v7.s:424: Error: bad instruction `endp '
src/v7.s:426: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:428: Error: bad instruction `export joinSMP'
src/v7.s:429: Error: bad instruction `void joinSMP(void)'
src/v7.s:430: Error: bad instruction `sets the ACTRL.SMP bit'
src/v7.s:431: Error: bad instruction `joinsmp PROC'
src/v7.s:433: Error: bad instruction `smp status is controlled by bit 6 of the CP15 Aux Ctrl Reg'
src/v7.s:435: Error: bad instruction `read ACTLR'
src/v7.s:436: Error: bad instruction `set bit 6'
src/v7.s:437: Error: bad instruction `write ACTLR'
src/v7.s:440: Error: bad instruction `endp '
src/v7.s:442: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:444: Error: bad instruction `export leaveSMP'
src/v7.s:445: Error: bad instruction `void leaveSMP(void)'
src/v7.s:446: Error: bad instruction `clear the ACTRL.SMP bit'
src/v7.s:447: Error: bad instruction `leavesmp PROC'
src/v7.s:449: Error: bad instruction `smp status is controlled by bit 6 of the CP15 Aux Ctrl Reg'
src/v7.s:451: Error: bad instruction `read ACTLR'
src/v7.s:452: Error: bad instruction `clear bit 6'
src/v7.s:453: Error: bad instruction `write ACTLR'
src/v7.s:456: Error: bad instruction `endp '
src/v7.s:458: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:459: Error: bad instruction `end of code'
src/v7.s:460: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:462: Error: bad instruction `end '
src/v7.s:464: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:465: Error: bad instruction `end of v7.s'
src/v7.s:466: Error: junk at end of line, first unrecognized character is `-'
src/v7.s:65: Error: invalid operands (*GAS `expr' section* and *ABS* sections) for `&'
src/v7.s: Error: can't resolve value for symbol `L0 '
src/v7.s:79: Error: invalid operands (*GAS `expr' section* and *ABS* sections) for `&'
src/v7.s:120: Error: invalid operands (*GAS `expr' section* and *ABS* sections) for `&'
src/v7.s:134: Error: invalid operands (*GAS `expr' section* and *ABS* sections) for `&'
src/v7.s:179: Error: invalid operands (*GAS `expr' section* and *ABS* sections) for `&'
src/v7.s:193: Error: invalid operands (*GAS `expr' section* and *ABS* sections) for `&'
src/v7.s:233: Error: invalid operands (*GAS `expr' section* and *ABS* sections) for `&'
src/v7.s:247: Error: invalid operands (*GAS `expr' section* and *ABS* sections) for `&'
Please guide me on how to resolve this error. Whether this v7.s file applicable to armv7-a ?
Please suggest me how to cross compile this example for ARMv7-a using command line.
Please guide me how to link scatter_normal.txt for "arm-none-eabi-" tool chain.
Regards,
Ajith
