I have searched information on Bit-Banding in Cortex-M3 and M4 with the GNU GCC ARM EABI NONE, I have seen basic examples on the internet but none works with GNU GCC also seems that no intention to have such feature implemented.
Can someone tell me if the LD via memory remapping really work? the best approach?
What is the best way?
can you be more specific on how you tested this?
I use bit banding for the peripheral memory range without problems, but by using direct access, without any expectations from the linker scripts.
Hi!
Liviu (ilg), I'm using to show my students the impact of Bit-Banding when migrating from AVR to ARM and unlike the technique used both for access to bit-fields in IO ports.
In case I did some testing with their own Arduino IDE, and enter the code below, and made the dump and the code is mixed C and Assembly, did nothing more than the statement of the variable and then assigns the value 1 to she.;
0008014c <loop>: ;volatile __attribute__((bitband, at(0x20000004))) uint32_t myFlag =0 ; ;void loop() { ; myFlag = B00000001; 8014c: 4b01 ldr r3, [pc, #4] ; (80154 <loop+0x8>) 8014e: 2201 movs r2, #1 80150: 601a str r2, [r3, #0] ;} 80152: 4770 bx lr 80154: 200708f0 .word 0x200708f0 I figured it did not reach the goal because of the memory address that is the variable, and then I search the internet in the ARM GCC site for windows saw the post that is the link to follow that would not be supported yet.
Question #228758 : Questions : GNU ARM Embedded Toolchain
Moreover, I suspect that lack a directive in the command, would it? But in issue up says it is not supported.
carlosdelfino, I'm not sure I understand what you want to show to your students.
bit-banding basically maps each bit to a word address, so a simple pointer arithmetic does the trick
(PERIPHERAL_BITBAND_BASE + (((registerAddress - PERIPHERAL_BASE) * 8) + bitNumber) * 4)
a functional template can be seen in an older µOS++ repository: micro-os-plus-iii-alpha/BitBand.h (the implementation needs some updates for the new µOS++ code style and C++ 14 goodies, but is functional).
This is a guess only, but I think carlosdelfino is teaching the students that if you need to set or clear a single bit, you can use a single write-cycle instead of read+modify+write cycle (3 or 4 clock cycles).
On AVR, it's necessary to read, then use either AND or OR and then write back the modified value.
That has a terrible disadvantage on the AVR. If you write to a port from an interrupt and you want to change a single bit from task-time, you risk that the interrupt will run in the middle of your read-modify-write cycle, which means that the values your interrupt writes will be available on the port for only a short time, then it's quickly changed back to what it was by your task-time.
To fix that, you can disable interrupts and re-enable them after updating the port at task-time (now 5 clock cycles were used instead of only 1 on ARM).
So one topic is the atomic access, the other topic is saving CPU-time on accessing the same port from both interrupt code and task-time code.
Exactly @Jensbauer
ilg I checked the example of uOS, but I believe it is not the time to introduce students to the C ++, even though a more advanced topic due to the use of Arduino maintein a low level overall.
I think very valid use of C ++ in microcontrollers, but some structures and the profile of the students who have worked makes the complex topic with C ++ since it would have to enter a preliminary study of the language C ++, even if they already have guidance notions object , as that C is already almost intuitive to them.
In GCC, I did not realize even attribute effect (AT) do not know what went wrong yet, I will do new tests. I hoped that at least he would allow me to allocate variáel in a specific position preventing the reuse of the address.
ilg I wanted to avoid using this macro.
I will now see the example in uOS.
The jensbauer perfectly conveyed my Intent, which comes down show atomicity in the use of bit-bading Cortex-M and the difference in the AVR.
then I'm afraid you need to use a macro. see the examples in Joseph Yiu's book (The Definitive Guide to ARM Cortex-M3 and M4, chapter 6.7.4).
personally I'm no longer that impressed with bit-band accesses; yes, they are atomic and they are fast, but only work for one bit. if you have a bitfield of 2 or more bits, don't be fooled into thinking that a sequence of bit-band accesses can be used, this is equivalent to setting a sequence of different values, which might not be what you want, not to mention that some of the intermediate values might be illegal.
I'm quite positive that it can be done with plain C and a linker-script (without using the macro).
The linker-script will need two special sections; one for bitband-access and one for normal access.
Then making two instances of the variable using 'volatile __attribute__((section("NAME")))', where NAME is for instance bitband_bits or bitband_vars.
It would be safest to group those two together, however, there's no guarantee that it will work well, if more than one bitband variable is used at a time.
carlosdelfino: The macro will be just as fast as the linker-script access, it's also the safest approach if you're not using Keil.
Well, the question does not move unseen by theme.
this is very important consideration when it comes to more than one bit, actually at the end ends up not being such a definitive solution, but anyway still win the amount of instructions.
Yes doubts in Jesph Yiu book is complete on this issue, but as I saw some discussions about the use of GCC thought something might have emerged something new after 2013 about the https://answers.launchpad.net/gcc-arm-embedded/+question/228758
Thanks for the suggestions.
View all questions in GNU Toolchain forum
