Hi everyone,
I am exporting a code from linux to windows 10 to program a microcontroller LPC1768. I am using visual studio code and when it compile I get the output show below. Also, in the image attached are the environment variables. I hope you could give me a hint for this.
Best Regards
It seems the problem is in file Link.txt
"C:\Program Files\CMake\bin\cmake.exe" -E rm -f CMakeFiles\program_test.dir/objects.aC:\MinGW\bin\ar.exe cr CMakeFiles\program_test.dir/objects.a @CMakeFiles\program_test.dir\objects1.rsp
arm-none-eabi-g++ -std=gnu++98 -fno-rtti -Wall -Wextra -Wno-unused-parameter -Wno-missing-field-initializers -fmessage-length=0 -fno-exceptions -fno-builtin -ffunction-sections -fdata-sections -funsigned-char -MMD -fno-delete-null-pointer-checks -fomit-frame-pointer -Os -mcpu=cortex-m3 -mthumb -g -Wl,--gc-sections -Wl,--wrap,main -Wl,--wrap,exit -Wl,--wrap,atexit -mcpu=cortex-m3 -mthumb "-TC:/Users/contr/Documents.../mbed-dev/targets/TARGET_NXP/TARGET_LPC176X/device/TOOLCHAIN_GCC_ARM/LPC1768.ld" -static -Wl,--whole-archive CMakeFiles\program_test.dir/objects.a -Wl,--no-whole-archive -o program_test.exe -Wl,--out-implib,libsauron-v1.0c.dll.a -Wl,--major-image-version,0,--minor-image-version,0 @CMakeFiles\program_test.dir\linklibs.rsp
if i quit these flag the output don recognize --minor-image-version Flag. I don't know where could be the problem.
Continued from: community.arm.com/.../arm-toolchain-visual-studio-code
Maybe I have issues with GNU Arm Embedded Toolchain in windows because I am trying to export a code form linux and there are some linux executables giving me troubles .
View all questions in GNU Toolchain forum
