Where to get, or how to build toolchain "aarch64 for aarch64 linux"?
I try to do as described in ABE release notes:
git clone https://git.linaro.org/toolchain/abe.git
run ../abe/abe.sh --manifest gcc-arm-aarch64-none-linux-gnu-abe-manifest.txt --build all
and
../abe/abe.sh --target aarch64-linux-gnu --build all
on aarch64 with debian buster, but got some errors.\\
RUN: (hello_world)RUN: aarch64-none-linux-gnu-g++ -o /tmp/hi /tmp/hello.cppIn file included from /abe/d/builds/destdir/aarch64-unknown-linux-gnu/aarch64-none-linux-gnu/include/c++/9.2.1/aarch64-none-linux-gnu/bits/c++config.h:524, from /abe/d/builds/destdir/aarch64-unknown-linux-gnu/aarch64-none-linux-gnu/include/c++/9.2.1/iostream:38, from /tmp/hello.cpp:1:/abe/d/builds/destdir/aarch64-unknown-linux-gnu/aarch64-none-linux-gnu/include/c++/9.2.1/aarch64-none-linux-gnu/bits/os_defines.h:39:10: fatal error: features.h: No such file or directory 39 | #include <features.h> | ^~~~~~~~~~~~compilation terminated.WARNING: Previous command failedWARNING: Previous command failedERROR (#71): build_step_HELLO_WORLD (Hello World test failed)ERROR (#118): perform_build_steps (Step HELLO_WORLD failed)ERROR (#309): build_failure (Build process failed after 46 minutes)
system:
root@27efb3f59b5d:/abe/d# lsb_release -aNo LSB modules are available.Distributor ID: DebianDescription: Debian GNU/Linux 10 (buster)Release: 10Codename: busterroot@27efb3f59b5d:/abe/d# uname -aLinux 27efb3f59b5d 5.8.12-meson64 #trunk SMP PREEMPT Sun Sep 27 00:11:54 EEST 2020 aarch64 GNU/LinuxDockerfiles:Ubuntufrom ubuntu:18.04ENV USERID=1000ENV DEBIAN_FRONTEND=noninteractiverun apt-get update; \ apt-get install -y autoconf automake libtool autogen wget gcc mc lsb-release sudo pkg-config \ git flex bison dejagnu libncurses5-dev zlib1g-dev texinfo python libpython2.7-dev alien gawk g++ rsyncrun wget raw.githubusercontent.com/.../git-new-workdir; \ chmod +x git-new-workdir; cp git-new-workdir /usr/local/bin/#run cp /usr/share/doc/git/contrib/workdir/git-new-workdir /usr/local/bin; chmod +x /usr/local/bin/git-new-workdirworkdir /aberun useradd -u $USERID -m user; \ echo "user ALL=(ALL) NOPASSWD:ALL" >> /etc/sudoers.d/useruser userCentOS:from centos:8ENV USERID=1000run yum install --enablerepo PowerTools -y autoconf automake libtool autogen wget gcc-c++ \ redhat-lsb-core git flex bison dejagnu which sudo mc \ ncurses-devel zlib-devel texinfo python2-devel#run wget raw.githubusercontent.com/.../git-new-workdir; \# chmod +x git-new-workdir; cp git-new-workdir /usr/local/bin/run cp /usr/share/doc/git/contrib/workdir/git-new-workdir /usr/local/bin; chmod +x /usr/local/bin/git-new-workdirrun useradd -u $USERID -m user; \ echo "user ALL=(ALL) NOPASSWD:ALL" >> /etc/sudoers.d/useruser userworkdir /abe
Does it say which version is needed?Standard releases are available here:developer.arm.com/.../downloads
There print "..or later".
I see no aarch64-hosted aarch64-linux-target available.
Then I want to build it myself, but fail.
there another try — to build just gcc, ubuntu 20.04:
../abe/abe.sh --build gcc
output https://pastebin.com/tjy6Yazf
View all questions in GNU Toolchain forum
