First of all, thank you so much for all the kind and detailed answer..
I am running simulation using cortex-53 or cortex-72 model, but my model does not support the below dup instruction.
I am using gnu compiler now.. so I tried to remove simd instruction by adding + nosimd option as below code..
ARCH = armv8-a+nosimd+nofp.
However, after doing compilation I still see dut instruction, no change.. Would you let me know how can I remove dup in my code ? (maybe disable simd..)
################### # AArch64 toolchain executables #AS64 := $(GCC_TOOLCHAIN_AARCH64)-as AS64 := /home/junieu/TEMP/gcc-arm-9.2-2019.12-x86_64-aarch64-none-elf/bin/aarch64-none-elf-as #GCC64 := $(GCC_TOOLCHAIN_AARCH64)-gcc GCC64 := /home/junieu/TEMP/gcc-arm-9.2-2019.12-x86_64-aarch64-none-elf/bin/aarch64-none-elf-gcc #LD64 := $(GCC_TOOLCHAIN_AARCH64)-ld LD64 := /home/junieu/TEMP/gcc-arm-9.2-2019.12-x86_64-aarch64-none-elf/bin/aarch64-none-elf-ld #OBJCOPY64 := $(GCC_TOOLCHAIN_AARCH64)-objcopy OBJCOPY64 := /home/junieu/TEMP/gcc-arm-9.2-2019.12-x86_64-aarch64-none-elf/bin/aarch64-none-elf-objcopy GCC_DISASS := /home/junieu/TEMP/gcc-arm-9.2-2019.12-x86_64-aarch64-none-elf/bin/aarch64-none-elf-objdump GCC_DISASS_OPTS := --disassemble-all -disassemble-zeros DISASSEMBLER := $(GCC_DISASS) DISASSEMBLER_OPTS := $(GCC_DISASS_OPTS) ################################################################################ # Processor options ################################################################################ # CPU and architecture #CPU = cortex-a53 CPU = cortex-a53 #2020.05.06 JU ARCH = armv8-a+nosimd+nofp # FPU types FPU_NONE := FPU_V8 := -mfpu=neon-fp-armv8 #FPU_V8_CRYPTO := -mfpu=crypto-neon-fp-armv8 # Active FPU, can be overridden by tests FPU = $(FPU_V8) #FPU = $(FPU_NONE) ################################################################################ # Commands and command options ################################################################################ # Assembler setup ASM32 = $(AS32) ASM64 = $(AS64) ifeq ($(findstring +bigend, $(PLUSARGS) ), +bigend) ASM_OPTS_AARCH32 = -march=$(ARCH) $(FPU) --defsym BIGEND=1 -mbig-endian ASM_OPTS_AARCH64 = -march=$(ARCH) --defsym BIGEND=1 -mbig-endian else ASM_OPTS_AARCH32 = -march=$(ARCH) $(FPU) --defsym EXEC_CPU=$(EXEC_CPU) ASM_OPTS_AARCH64 = -march=$(ARCH) --defsym EXEC_CPU=$(EXEC_CPU) endif # C compiler setup CC32 = $(GCC32) CC64 = $(GCC64) ifeq ($(findstring +bigend, $(PLUSARGS) ), +bigend) CC_OPTS_AARCH32 = -march=$(ARCH) -mtune=$(CPU) $(FPU) -c -DGCC -falign-functions=16 -fno-common -falign-jumps=8 -falign-loops=8 -fomit-frame-pointer -funroll-loops -g -mbig-endian CC_OPTS_AARCH64 = -march=$(ARCH) -mtune=$(CPU) -c -DGCC -falign-functions=16 -falign-jumps=8 -falign-loops=8 -fomit-frame-pointer -funroll-loops -g -mbig-endian else CC_OPTS_AARCH32 = -march=$(ARCH) -mtune=$(CPU) $(FPU) -c -DGCC -falign-functions=16 -fno-common -falign-jumps=8 -falign-loops=8 -fomit-frame-pointer -funroll-loops -g CC_OPTS_AARCH64 = -march=$(ARCH) -mtune=$(CPU) -c -DGCC -falign-functions=16 -falign-jumps=8 -falign-loops=8 -fomit-frame-pointer -funroll-loops -g endif
View all questions in GNU Toolchain forum
