std::tuple assembly code
Hello
I try to add some generalization into the C++ project thus I use std::tuple to hold fields.
I'm investigating the difference in assembly code between std::get<1>(myClass.myTuple).read() and myClass.myField.read().
myField.read() is compiled as:
9A02                ldr        r2, [r13, #8]
E71F                b          #0x16a0
which is obvious and expected.
While std::get<1>(myTuple).read() is compiled as:
9B82                ldr        r3, [r13, #0x208]
695B                ldr        r3, [r3, #0x14]
42AB                cmp        r3, r5
D11B                bne        #0x1a3c
F8BD0210            ldrh.w     r0, [r13, #0x210]
E761                b          #0x1792
In theory std::get has to be evaluated in compile-time and the result should be similar in both cases.
For what reason do we get this additional comparison?
42AB                cmp        r3, r5
D11B                bne        #0x1a3c
I cannot find any situation when the code follows this branch.
What can I do to simplify this code?
Can I change something in my C++ code to get a result equivalent to direct field access (myField.read())?
How can I force the compiler not to generate this additional piece of code?
Any help is appreciated.
/Adam
