Helllo,I'm using makefile to compile my source files but there is something strange that happens, when I include header file with absolute path they compile correctly but when I switch to relative paths they work fine also except a directory although the directory path is correct, is there a solution for this?There error is:Fatal error[Pe1696]: cannot open source file "DMEM_int.h"
View all questions in GNU Toolchain forum
