Greetings,
Im experiencing strange behaviour of my DS-5 debugger when I try to #include <tuple>. After including this header, my debugger gets messy (i.e Variables window is not showing any local scope data, program is not running from symbol main stucking at _ZL20__gthread_key_deletei symbol). Do i have to add something while compiling to support this feature ? To clarify, program and all tuple stuff compiles and works as expected - only debugger seems to get broken.
Im linking with --specs=nosys.specs -nostartfiles -T ${CMAKE_SOURCE_DIR}/linker/script.ld
Thanks for reporting. I don't think compiler need any special feature to support including of a standard header file. You migh want to try if gdb has the same issue with your case?
Hi, What do you mean by that ? :D I think i solved this issue by forcing -gstrict-dwarf (after I've found this thread community.arm.com/.../ds-5-fvp-debugger-always-shows-failed-to-load-symbols-for-hello-world-axf). Is there any official statement about any debug related GCC flag which should be used while debugging in DS-5 ?
View all questions in GNU Toolchain forum
