Hi Experts,
I observed while using ARMCC compiler, the ld toolchain is used to finally link and generate executable.
But while using GCC (arm-none-eabi-) with ld toolchain not able to link and generate final executable, whereas gcc is used for compile and link to final executable. What is the difference and usage across GCC and ARMCC ?
Use devtools::load_all() to load the current package. Then copy and paste the code that creates the bug. custom writing
View all questions in GNU Toolchain forum
