Hi Experts,
There was undefined reference to the snprintf() function during linking using arm-none-eabi compiler.
Compiler version: arm none-eabi gcc 4.5.1
Compiler options: -nostdlib -nodefaultlibs -nostartfiles -msoft-float -mfloat-abi=soft -Wformat -mthumb -mfix-cortexm3-ldrd
Hi Andy,
Removing -nostdlib has no effect. But removing -nodefaultlibs lead to link error as follows,
.text has both ordered [`.ARM.extab' in libgcc.a(_divdi3.o)] and unordered [`.ARM.exidx' in libgcc.a(_divdi3.o)] sections
Likely due to linker script problem. Most of linker usage problem can be resolved by following the sample projects delivered with toolchain. To do so you can go to share/gcc-arm-none-eabi/samples, and follow the command line and linker script in projects there. Hopeful it helpful.
Hi Joey,
Thanks for the update. I re-checked and it uses the following sequences in linker file which collides in order vs unordered linking. Also this happens specifically when I am trying to access functions like snprintf() and vsnprintf().
.ARM.extab : { *(.ARM.extab* .gnu.linkonce.armextab.*) } > FLASH __exidx_start = .; .ARM.exidx : { *(.ARM.exidx* .gnu.linkonce.armexidx.*) } > FLASH __exidx_end = .;
your answer is unclear
looks like an attempt at putting spam links in a post ?
