GNU ARM Embedded Toolchain takes more time to compile on Windows 10 than Windows 7
This query is regarding the time difference the GNU ARM Embedded Toolchain takes to build a system on Windows 10 vs Windows 7.
Earlier I was using Windows 7 for compilation of a large bare metal system(around 5000 files) and it took around 2.5 hours to complete the build.
Now, I migrated to Windows 10 and it takes around 12 hours to complete the same build.
Executables used:
1) arm-none-eabi-gcc.exe
2) arm-none-eabi-as.exe
3) arm-none-eabi-ld.exe
It would be really great if you could direct me in the right direction to resolve this issue and if there's anyway to reduce the build time.
  • Hi,
    Could you possibly reduce this down to the files in the compilation that takes the longest? It would be good to find a test case that is representative of the delay in compilation. You could append a time to the compilation command line in your make file where you invoke the compiler (eg. CC = 'time arm-none-eabi-gcc'). You could then parse and compare the logs on Windows 10 and 7. More info will be helpful eg are you doing the build under a cygwin environment? Cygwin usually adds another layer to the execution.
    Thanks,
    Tejas.
  • I have found anti virus software that scans an executable every time it is run will make my builds about 5 times longer.  You seem to be right at that mark so that would be my guess.  Either stop the Anti Virus or make if not scan "arm-none-eabi-gcc.exe" each and every time it is invoked.   (I don't seem any issue between Windows 7 and Windows 7 for build times)
  • Is this on different computers, or is it the same computer that's been updated (sic?) from Win-7 to 10 ?
    If different computers, are the Win-7 and Win-10 machines otherwise identical?
    Have other applications similarly slowed?
