Hi,I am trying to migrate GCC from 7.2.1 to 8.3.To do so, I took the prebuilt binaries from your websitedeveloper.arm.com/.../downloadsI used to take the packages from Linaro in the past.I am using the bare metal binaries for AArch64.I have the following link error:gcc-arm-8.3-2019.03-x86_64-aarch64-elf/bin/../lib/gcc/aarch64-elf/8.3.0/../../../../aarch64-elf/bin/ld: gcc-arm-8.3-2019.03-x86_64-aarch64-elf/bin/../lib/gcc/aarch64-elf/8.3.0/../../../../aarch64-elf/lib/libc.a(lib_a-stack_protector.o): in function `__stack_chk_fail':/tmp/dgboter/bbs/rhev-vm2--rhe6x86_64/buildbot/rhe6x86_64--aarch64-elf/build/src/newlib-cygwin/newlib/libc/ssp/stack_protector.c:32: multiple definition of `__stack_chk_fail'; /tlCrt0Init.S.o:(.text.__stack_chk_fail+0x0): first defined hereIn our code, it is true that we define __stack_chk_fail() because it is a bare metal implementation and we need to do something really specific to our environment.In the libc.a provided by Linaro in 7.2.1, this function for the stack protection was not defined.I guess that the developers had to link with libssp.a.I have to link with the libc because I need memcmp, memcpy but I don't want the default implementation of the SSP hooks.Do you have any advice? Is it intended?Thank you,Alexandre.
View all questions in GNU Toolchain forum
