I have a project where I need to define strong function in ASM. If I do so it gets ignored and default weak function is used instead. If I define strong function in C it works fine, that is strong one will be called.
If I add the following code to C, then strong ASM function will be called.
extern void SVC_Handler(void); void(*SVC_Handler_fp)(void) = &SVC_Handler;
I tried changing linking order but it doesn't help. Any way to fix this without using global memory?
this is a linker command line
c:\SysGCC\arm-eabi\bin\arm-eabi-g++.exe -o ../../../VisualGDB/Release/det-os-example-stm32l496ze -Wl,-gc-sections -TC:/Users/USAGu/AppData/Local/VisualGDB/EmbeddedBSPs/arm-eabi/com.sysprogs.arm.stm32/STM32L4xxxx/LinkerScripts/STM32L496ZG_flash.lds --specs=nano.specs --specs=nosys.specs -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mcpu=cortex-m4 -Wl,--start-group VisualGDB/Release/main.o ../../../VisualGDB/Release/lib-det-os-stm32l496ze.a ../../../VisualGDB/Release/lib-stm32l496ze.a -Wl,--end-group:
lib-det-os-stm32l496ze.a has a strong ASM function.
https://github.com/robot-corral/mazebot/blob/master/software/common/lib-det-os/src-asm/svc_handler.S
lib-stm32l496ze.a has a weak ASM function.
https://github.com/robot-corral/mazebot/blob/master/software/common/lib-stm32l4/src/startup_stm32l496xx.s
Function name is SVC_Handler
GCC v7.2
LD 2.29
View all questions in GNU Toolchain forum
